by John Richard Procter » Mon May 30, 2011 1:20 pm
- This error means that the soundcard is being used by another application.
Check the following: - If more than one USBclient is open at the same time on the PC.
- Other applications that may be accessing the sound card simultaneously (Skype) etc.
- Multiple Windows users can be logged in one PC at a time, if the USBclient is in the startup
for all users, one will open each time another user logs in the PC.
SCard=Sound card
