- Log into Amethyst Web Admin.
- Go in the "system" section then click on, "view log files."
- A page will appear which has all of the type of logs that can be viewed.
On this page one can select to go to previous months, it has a drop down under the month which consists of the days of the month. Click on the day you wish to see , nothing will appear only the selected date shows. - Then click on the log which is needed to veiw. Eg server log:
There are two download options:
- Download log- text document
- Download compressed log- Zip folder
Also see: How do I view 7-zip log files I downloaded from Webadmin?
