by Belinda Frick » Tue Nov 16, 2010 8:38 am
Right click on your desktop and then on properties. Go to the settings tab
and then click on the advanced button:
- On the troubleshooting tab you can turn off the hardware acceleration.
- If this still does not work you can disable screenshots to this PC.
