How do I check if my update was done and that it has the new
Postby John Richard Procter » Wed Jun 22, 2011 12:57 pm
RELEASE NOTES: How do I check if my update was done and that it has the new versions?
The update on the internet under the member area for AMETHYST, for
example 'amt-1_5_server-update-1_5_2_1.amt', includes all of the
latest AMETHYST versions. If for example the release only contains
the AMTListen version update, only the version of that application
will change. However, for example the server and supervisor is also
uploaded and therefore if you were already on that server and supervisor
version, their version numbers stays as is.
In the update name 'amt-1_5_server-update-1_5_2_1.amt', the '-update-1_5_2_1'
refers to the internet update version. Please check release notes for
version number of the individual application.
This update method will ensure that each time one applications is
released the system will be updated to all the latest versions of AMETHYST.
Content of the upgrade is:
For the AMETHYST server:
  1. Admin,
  2. server,
  3. sweeper,
  4. smdrlink,
  5. images,
  6. scripts
    For distrubtion:
  7. USBClient
  8. AMTListen
  9. AMTCards
How do I check if the update was uploaded?:
The upload steps will be listed in the AMETHYST Admin log.
Select the 'View logs' link from the 'AMETHYST Home Page',
    then the 'Admin log' link and click on 'today'
    Example of Admin log entry:
    [2006-07-18 15:59:16] Version [1.5.2.0]******** UPGRADE EXECUTION STARTS HERE *************
    Installing /tmp/amtupgrade/admin_upgrade.tar.gz
    dtx/
    dtx/getsetwebadmin
    install
    cp: cannot create regular file `/opt/getset/bin/getsetwebadmin': Text file busy
    Finished /tmp/amtupgrade/admin_upgrade.tar.gz
    [2006-07-18 15:59:17] Version [1.5.2.0]******** UPGRADE EXECUTION STOPS HERE *************
    How do I check if the new release version was updated?:
    When a new version is released all maillist subscribers is notified
    via e-mail. This e-mail will notify you which AMETHYST application
    was upgraded. Only the version number of this application will change.
    Please note that applications that is only available on request
    from Datatex does not have release notes.
    In AMETHYST 1.5 Administrator the versions is listed under:
    1. the 'Latest Versions' on the 'AMETHYST Home Page'
      Example of applications version display:
      WebAdmin 1.5.2.0
      Sweeper 1.5.1.0
      Supervisor 1.5.2.0
      Server 1.5.1.1
      GetSet WebAdmin 1.0.0.1
      SMDR link 1.1.0.1
    2. the 'Distributions' page.
Click on the 'Distributions' icon in the AMETHYST Administrator
to go to the 'Distributions' page.
Example of distributions version display:
USB 1.5.0.12
USBUpdate 1.5.0.12
Template 1 1.0.0.0
AMTCards 1.0.1.0
AMTListen 1.0.2.0
