AMETHYST recording missing:.."archive appear to be corrupted
Postby John Richard Procter » Thu Jun 23, 2011 10:17 am
  • This could be a problem with the ftp. Which is caused by a
    slow network or network problem. The files are properbly in
    the work folder.
  • If the network is slow and the ftp takes very long, the sweeper
    can move the file before the ftp was complete and therefore it
    seems like it is corrupted.
  • Look in the ftp log file. When you compare the transfer rate of
    the different sessions it will show out the problem PC.
  • You can move the files in the work folder to the temp folder. The
    sweeper will try to update it. Check in the sweeper log if the
    files were processed.
    Under investigation!
