Installing a Amethyst Supervisor on another pc (before 1.4)
Postby Belinda Frick » Tue Nov 16, 2010 9:07 am
AMETHYST 1.3 no longer supported, please
contact your dealer for upgrade options!
First install a client version of interbase on the desired pc.
Copy the
AMTSuper.exe and
AMTSuper.ini
from the old pc to the same location on the new pc (if the path doesn't exist then create it).
Create a new supervisor in AMT (server) and run the supervisor and login.
