by John Richard Procter » Thu Jun 23, 2011 6:01 pm
- Go to control pannle and modem options
- Go to advance in the phone and modem options. Double click on the Mitel PBX Tapi Service Provider.
- There will now be a Mitel device properites page.
Right click at the bottom of the page, there will now be a tab with a insert option. Click on the insert tab.Mitel Device.PNG
- Prime DN= extension number
- The device type in the drop down should be "station mode"
- Name should be the name of the person you are adding the extention to.
- The Prem LineID and Sharing should automatically be added.
- Once complete click apply
- The device should now be at the bottom of the screen or where there is blank. If it's the first time adding a device.
- Click "OK" on the Mitel Device Properties
- Accept the warning if one appears.
