Error "530 Cannot set root directory" in my SLVR log
Postby Belinda Frick » Tue Nov 16, 2010 9:16 am
The problem is on the server.
The directory in GuildFTP is incorrect, or possibly GuildFTP doesn't have
rights to access that folder.
Make sure that it is a valid path, and that GuildFTP has rights to the folder.
Also check that the Virtual path is setup correct. There must not be a space
befor or after the "/". Just wipe out the whole field and enter a "/" only.
( Do not include the Quote signes )
