Amethyst SLVR doesn't want to start recording
Postby Belinda Frick » Tue Nov 16, 2010 9:21 am
Amethyst SLVR doesn't want to start recording. [MMSYSERR_ALLOCATED error in the log file]
This problem occurs when the first sound devices detected by Windows is not your
sound card. If you look at the sound settings in your Control panel, you will
see that there are multiple sound recording devices that you can select from.
The drop down for Recording devices, will contain at least 2 devices and the
first one is not your sound card. Find the correct recording device, count
from the top and find out which number the recording device is.
Now subtract 1 from this number and remember or write it down.
Open the SLVR.INI file. You must ensure that your SLVR is closed first.
Find the WAVEINDEVICE= Value and change it to the value that we counted earlier.
Now save the INI file and start the SLVR again.
This should solve the problem.
