SmartTAP DP card configuration
Postby Belinda Frick » Tue Nov 16, 2010 9:43 am
This is just a working configuration.
You need to enable each of these settings on all cards. Select the card
you want to configure on the Boards tab and then go and change the settings.
After installing the SmartWORKS software, click on
Start -> Settings -> Control Panel -> SmartControl.
System
H100 Stream Speed = 2048 Khz
GCI Starting Index = 0
No Bus Segmentation
Board
TDM Encoding = A-law (important!)
CT Bus Type = MVIP
CT Mode = Master
Digital Network
T1E1 Option = E1 (important!)
Framing = Basic G.704 (or CRC-4 if you use that)
Line Coding = HDB3 (important!)
Signaling Protocol = ISDN (important!)
NOTE!!!
When the PRI cable has been removed from the boards while the server is on,
the server doesn't seem to respond correctly anymore. The server should then
be restarted to ensure that everything function correctly.
