Wiring for Amethyst Primary Rate ISDN (PRI)
Postby John Richard Procter » Wed Aug 31, 2011 2:28 pm
Wiring for Amethyst Primary Rate ISDN (PRI) recording solution
  1. Description of card and cable:
    DP3209
    Digital recording card for primary rate ISDN (PRI).
    1 x 4m cream flat cable with 8 wires, RJ-45 connector on one end, all 8 wires
    connected.
    DP6409
    Digital recording card for Primary rate ISDN (PRI)
    2 x 4m cream flat cables with 8 wires, RJ-45 connector on one end, all 8
    wires connected.
  2. Specifications of the cable:
    Very important!: Shielded Cat5 cable that is properly earthed on both sides.
  3. Suggested cable lengths: 4 meters
  4. Pin layouts:
    Make sure that the cable is disconnected or the PC is off before you connect
    it to the PRI.
    On the Telecom chrono-block, there will be 2 pairs of wires, CUSTOMER TX OUT,
    and CUSTOMER RX IN.
    Turn the RJ-45 connector so that the clip points downwards, and the
    cable is towards your body. The pins are numbered from the left,
    starting at 1. We are only interested in pins 1,2,4 and 5.
  • 4-wire cables
    On the cables supplied by Datatex, pin 1 is a YELLOW wire, pin 2 is a GREEN
    wire, pin 4 is a BLACK wire, and pin 5 is a YELLOW wire. Just remember that
    the YELLOW wire in the middle is pin 5, and the YELLOW wire at the end is
    pin 1.
    Connect pin 1 of the RJ45 (YELLOW wire) to pin 2 of the CUSTOMER TX OUT.
    Connect pin 2 of the RJ45 (GREEN wire) to pin 1 of the CUSTOMER TX OUT.
    Connect pin 4 of the RJ45 (BLACK wire) to pin 2 of the CUSTOMER RX IN.
    Connect pin 5 of the RJ45 (YELLOW wire) to pin 1 of the CUSTOMER RX IN.
  • 8-wire cables
    On the cables supplied by Datatex, pin 1 is a GRAY wire, pin 2 is an ORANGE
    wire, pin 4 is a RED wire, and pin 5 is a GREEN wire.
    Connect pin 1 of the RJ45 (GRAY wire) to pin 2 of the CUSTOMER TX OUT.
    Connect pin 2 of the RJ45 (ORANGE wire) to pin 1 of the CUSTOMER TX OUT.
    Connect pin 4 of the RJ45 (RED wire) to pin 2 of the CUSTOMER RX IN.
    Connect pin 5 of the RJ45 (GREEN wire) to pin 1 of the CUSTOMER RX IN.
    Plug the cable into the server, and switch it on.
    When the Amethyst PRI software is started, the light on the card must turn green.
