critical mail: Recording...change.log-?? ...was not found
Postby Belinda Frick » Fri Dec 02, 2011 2:26 pm
[2011-11-29 22:39:50] Version [1.6.3.18] Recording /mnt/drive3/20100906/1_fbc217b5is specified in /opt/amethyst/bin/hdd/change.log-bk was not found
[2011-11-29 22:40:04] Version [1.6.3.18] Recording /mnt/drive3/20100906/1_fbc217b5is specified in /opt/amethyst/bin/hdd/change.log-1 was not found
[2011-11-29 22:41:53] Version [1.6.3.18] Recording /mnt/drive3/20100906/1_fbc217b5is specified in /opt/amethyst/bin/hdd/change.log-2 was not found
The error message is to state that the recording for the reference listed(in this case '1_fbc217b5is) was not found in the location specified(in this case 'mnt/drive3/20100906').
This could happen if:
  • the sweep process was interrupted and the recording file could not be written to the exclusive drive, for example during a power failure or the AMETHYST server was switched off without using the shutdown option in AMETHYST Webadmin.
  • the exclusive drive is damaged
  • the file system of the exclusive drive is damaged
