How do I check my AQM template configuration?
Postby Belinda Frick » Thu Dec 08, 2011 10:03 am
When you log into AMETHYST Supervisor and have access to do AQM, you will have the option to print AQM reports.
Print blank AQM template:
    AMETHYST Supervisor, go to the AQM Reports page.
    Click on the drop-down for 'AQM Report' and select 'Blank Review'.
    Click on the drop-down for 'Template List' and select the template name you wish to view.
    Cick on 'Preview'.
    Note that the report will display the Categories and Questions in it, but not the points allocated. You can use it to decide on point allocation per Category and point per Question.
Edit the AQM Template:
