Sweeper.log: ...zlb open in another process, skipping
Postby Belinda Frick » Fri Dec 23, 2011 10:19 am
Admin.log:
[2011-12-22 12:09:41] Version [1.6.4.2]******Critical Errors sent to support@support.co.za *******
[2011-12-22 12:09:41] Version [1.6.4.2][2011-12-22 12:09:35] Sweeper stopped, last 10 recordings gave errors.
[2011-12-22 12:09:41] Version [1.6.4.2]******End Critical Section*******
Critical e-mail sent:
Sweeper.log:
[2011-12-22 12:08:15] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:08:25] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:08:35] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:08:45] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:08:55] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:09:05] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:09:15] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:09:25] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:09:35] Version [1.6.4.3]File A111222-00046E.zlb open in another process, skipping...
[2011-12-22 12:09:35] Version [1.6.4.3]Sweeper stopped, last 10 recordings gave errors.
VOIP Recorder log:
2011-12-22 12:13:18.593 [1.6.4.2] RecordingStarted - A111222-00046E for station 1 (10.133.30.33 / 00:80:9F:7D:E4:B2) extension 72221 number
2011-12-22 12:13:33.241 [1.6.4.2] RecordingStopped - A111222-00046E for station 1 (10.133.30.33 / 00:80:9F:7D:E4:B2) extension 72221 number
2011-12-22 12:13:33.241 [1.6.4.2] Recorded(DT2)=>EXT:72221,USER:,LINE:VOIP,NUMBER:INCOMING,DURATION:0:00:14,INCOMING(A111222-00046E.ZLB)
VOIP sweeper log:
2011-12-22 12:13:51.571 [1.6.4.1] Recorded(DTA)=>EXT:72221,USER:,LINE:VOIP,NUMBER:INCOMING,DURATION:0:00:14,INCOMING(A111222-00046E.ZLB)
2011-12-22 12:14:06.438 [1.6.4.1] Error in FTPThread: EIdSocketError error uploading A111222-00046E.zlb to 192.168.203.160: Socket Error # 10013
Access denied.
    The VOIP Recording software will send the zlb file over the network to the AMETHYST server to be sweeped into the database. If the FTP is slow then it can try to sweep the file before the ftp has completed.
    The FTP should be a LAN connection, so it shouldn't be slow unless the file is very big.
    If the file is big, it could be a problem with the VoIPRecorder. Please find the recording(search in Supervisor using reference number listed in sweeper.log) and check the size?
    If the file is small, then the LAN is very slow.
UNDER INVESTIGATION!
