Amethyst doesn't auto purge
Postby Leon van Heerden » Wed Jan 18, 2012 9:27 am
If you enable Auto purge and it doesn't automatically purge at 00:00 check the following:
  • Run a manual purge and ensure that this functions properly
  • Check in the Amethyst Admin log in there is a error message at 00:00 and address this error if there is one
  • The last resort will be to restart the Amethyst Webadmin; if you do not have access to do this, restart the Amethyst server when it is possible.
