I try to playback a recording and my internet explorer hangs
Postby John Richard Procter » Fri Feb 03, 2012 12:18 pm
When trying to playback a recording my internet explorer hangs.
I uninstall internet explorer and reinstall it but to no success,it still hangs.
We Suggest you user Mozilla Firefox refer to the link How to install firefox on a windows machine
Once downloaded and installed:
Enter your Amethyst IP address e.g. 192.168.10.6
  • You will be prompted with a untrusted connection
  • Select I Understand the Risks
  • There will be a Add exception tab , select this.
  • Select the Confirm Security Exception , make sure Permanently store this exception box is ticked.
    This will insure that you will not have to do this step again.
  • Log into the supervisor and select the recording you wish to listen too.
  • A additional download is required to embed the media player. In the top right corner select the tab install missing plugin.
  • Firefox will automatically download the plugin
  • You will now be able to playback recordings.
