I want to upgrade to AMETHYST Supervisor 1.6.4.5 or newer
Postby Belinda Frick » Thu Feb 16, 2012 10:58 am
NOTE:
Only upgrade if your AMETHYST is already on version 1.6.3.18
See release notes:
Release notes: Supervisor version 1.6.4.4
Steps to upgrade:
  • VERY IMPORTANT: First upgrade AMETHYST server.
    NOTE: This will make changes to the database. Please check Admin logs when archive(21h00 each night) and purge(00h00 each night, if enabled) takes place to ensure no database problems.
  • Unrar, password is 'datatex'.
    server-guardian-1_6_4_3-password.rar
  • To upgrade follow steps in forum post: How do I upgrade with AMETHYST 1.5 /1.6?
  • Upgrade AMETHYST Supervisor.
    supervisor-update-1_6_4_5-password.rar
  • Upgrade AMETHYST Sweeper.
    sweeper-update-1_6_4_6-password.rar
    NOTE: If you use the cardserver as recording solution, AMTCards 1.6.3.11 requires Sweeper 1.6.3.14 or newer.
