More about AMTExclusive when Upgrading to Amethyst 1.4
Postby Belinda Frick » Tue Nov 16, 2010 11:10 am
AMETHYST 1.3 no longer supported, please
contact your dealer for upgrade options!
Before running AMTExclusive also see:
How to upgrade to
Amethyst Version 1.4 for Windows
Purpose:
Used for moving your database to a new location as
part of upgrading to Amethyst Version 1.4.
(This includes specifying new locations for all your
screenshot- and recording files. As well as creating
a new database file with DBCreate beforehand.)
Running the executable:
Click the OK button to start.
Select the filepath where your live database is
currently running. Now select the database file
e.g. AMT.gdb
Select the filepath where you would like to move
your database to. If you created a new database
with DBCreate, this file e.g. AMT.fdb, should
already be located in this filepath.
Select the filepath(s) for your audio and
screenshot location(s). Subdirectories will automatically
be created based on the date the recordings and screenshots
were made. It will move to the next location specified,
as soon as there is only 100 meg space free
on the drive.
E.g. A recording made on 21 June 2004 may be found in:
C:\FolderSpecified\20040621\
A message will indicate when AMTExclusive has successfully
completed. Only close the program AFTER this message has
been displayed.
