My SLVR sometimes pops up even when I am not at work
Postby Belinda Frick » Tue Nov 16, 2010 11:12 am
If you are using a laptop, the recording is being triggered by the
built-in mic on the laptop. Remember when you plug in a teletap
it connects to the mic of the sound card and disconnects the
built-in mic. When you unplug the teletap the built-in mic becomes
active again and this will pick up noises from the surrounding
environment. This will cause the SLVR to start recording.
Change the start-up for home and office by creating different users
or "kill" the SLVR when you are not at work. Alternatevely you can
plug a "dead connector" into the sound card.
NOTE: All these recordings will be dumped on the server the next time it
is connected to the network at your office.
