How to use the AmtMirror program
Postby Belinda Frick » Tue Nov 16, 2010 11:13 am
The program will move the Reviews, Template and supervisor tables
from the SOURCE database to the DESTINATION database.
It will also copy the Supervisor comments, shortnotes, Agent Status
Agent status, Agent score, and Lastreview date from the SOURCE recording
to the DESTINATION recording table.
AmtMirror will process all the recording table entries that has been changed
since the last time it was run to the current date and time. It will then
save the date and time when the program was started up.
Here is an example of what the INI will look like.:
[Paths]
SourcePath=SourceComputer:c:\program files\datatex\Amethyst\data\amt.fdb
DestinationPath=DestComp:C:\Program Files\Datatex\Amethyst\Data\amt.fdb
IGNOREVERSIONS=1
[General]
LastExecuted=38153.0000003588
;this date is 15 June 2004 00:00:00
ToDate=38161.0000003588
;this date is 23 June 2004 00:00:00
The IgnoreVersions option can be used if you need to mirror your info
from 2 different versions of the Amethyst databases.By default this
option is not included in the INI file.
The LastExecuted and To dates are in an encoded date format.
The ToDate is not included in the INI file by default, since the current
date and time will always be sued as the ToDate.
