critical mail: ...kernel: ...I/O error, dev sdf
Postby Belinda Frick » Thu May 03, 2012 10:17 am
[2012-05-03 10:25:56] Syslog log, : Apr 29 21:42:19 amethyst kernel: end_request: I/O error, dev sdf, sector 95
[2012-05-03 10:25:56] Syslog log, : Apr 30 21:42:32 amethyst kernel: end_request: I/O error, dev sdf, sector 95
To see which drive is 'dev sdf', log into AMETHYST webadmin and select 'Available Diskspace' from the Home page:
In this example 'dev sdf' is the archive drive and the archive drive is an USB drive. You can connect this USB drive to a Windows PC and run a check disk on it.
Archiving can be to either USB drive or NFS, see:
UNDER INVESTIGATION
