How to change AmtCGI to work with Amethyst 1.4
Postby Belinda Frick » Tue Nov 16, 2010 11:25 am
1. Get the new AMTCGI.exe V1.1.1.0.
Install the to C:\Program Files\Common Files\Microsoft Shared\
web server extensions\40\isapi\
2. Get the new Amethyst server V1.4.0.4
3. Change the URL to also give a supervisor name at the end.
eg.
http://127.0.0.1/_vti_bin/amtcgi.exe/search?
reference=XX_XXXXXXXX.GSM&supervisor=YYYY.
If the supervisor is not valid, amtcgi will timeout and not retreive the record.
4. Put the server's host name and the port number that it will be listening on in the
ini file of the AmtCGI program.
eg.
[AMTCGI]
DATABASENAME=gem:C:\Program Files\Datatex\Amethyst\Data\amt.fdb
WEBPATH=C:\Inetpub\wwwroot\amt
WEBSERVER=http://gem/amt
IMAGEPATH=/images/amethyst.jpg
SERVERHOST=gem
SERVERPORT=27000
Note
If someone is allready busy retreiving a recording, the amtcgi
program will display a error page that will tell you that it is allready busy.
