Open SmartView
System
MTSysStartup
Highlight Channel for testing.
Click Settings
MT(Get/Set)AGC
Start with Target Max Amplitude level at 12 - 15 dBm and
Max Amplification around -10 db.
Leave Attack and Decay values as default.
Check Enable
Click Set
Click Close
Change values until both sides are equal levels, don't
worry about volume at this point. After both sides are
equalized Click Settings
MT(Get/Set)Gain
Change value to desired level.
