I am using Chrome and I cannot playback my recordings
Postby Belinda Frick » Wed Jun 20, 2012 2:23 pm
I am using Chrome and when I select a recording to playback in AMETHYST Supervisor,
it displays 'funny characters', starting with 'RIFF' and also the wording 'WAVE' where the play button should be:
When you use Chrome as your Browser,
you must install Quick Time as your Media Player.
Solution: Please download Quick Time from the internet and install on your PC.
NOTE: If you use Internet Explorer you will not have this problem.
