AmtSuper error:Adding AQM templates:Updating templates table
Postby Belinda Frick » Tue Nov 16, 2010 11:35 am
When setting up the template,
the template name and category name
has to be shorter than 30 chars.
This error will appear if it is longer
than 30 chars.
You may not use single or double quotes
There are no limit on the length of the question.
ALSO SEE: For the agent reviews,
is there a limit on the length of the questions?
