Amethyst Network Archive error: "I/O Error 17"
Postby Leon van Heerden » Mon Oct 15, 2012 3:09 pm
If you use the Windows Share facility to archive to a network location and you receive the following error:
I/O Error 17
in your Amethyst Webadmin logs and your Windows Share is located on a 64 Bit server, you will need to get the latest Amethyst Archive update(At least after 2012-07-20).
The latest version can properly detect and merge folders on a 64 Bit share.
