Upgrading Amethyst 1.3 to 1.4 from the internet (Windows)
Postby Belinda Frick » Tue Nov 16, 2010 12:04 pm
AMETHYST 1.3 no longer supported, please
contact your dealer for upgrade options!
ALSO SEE: Utilities to process data in Amethyst version 1.4 onwards.
ALSO SEE: How to use amtrsmove.exe
Downloads required:
www.datatex.co.za -> Downloads -> Amethyst Section
Amethyst.Upgrade.Database.1.4.exe
Amethyst.Server.Windows.Upgrade.1.4.0.6.exe
Amethyst.Supervisor.Upgrade.1.4.0.8.exe
Amethyst.SLVR.Upgrade.1.4.0.3.exe
Amethyst.USBClient.Upgrade.1.4.0.9.exe
www.datatex.co.za -> Downloads -> Miscellaneous Section
Firebird
Steps to follow:
Download all the required software.
Close all Amethyst Applications.
Make a full backup of Amethyst.
On the Amethyst Server:
Run Amethyst.Upgrade.Database.1.4.exe
This will extract the files you need for the upgrade:
Please note: Do not run the files listed below proceed to step 5!
AMT_Exclusive.exe
amt.sql
amtrsmove.exe
amtrsmove.ini
AMTUPGRD.exe
DBCreate.exe
fbclient.dll
midas.dll
msvcp60.dll
qtintf70.dll
The database upgrade: Interbase 1.3.
To do the upgrade, the database 'must' be Interbase 1.3
If not, upgrade to 1.3 by running AMTUPGRD.exe
The database upgrade: Interbase will be replaced with Firebird.
Follow procedure to uninstall Interbase and install Firebird:
ALSO SEE: How to upgrade to Amethyst Version 1.4 for Windows
ALSO SEE: More about AMTExclusive when Upgrading to Amethyst 1.4
Run the server upgrade.
You will get the following message after excepting the
file path:
"Please note This will update all files in your Amethyst
Server Directory. The database needs to be upgraded after
this update. Please run the AMTUPGRD.exe after backing
your database up. "
You can ignore this, since AMTUPGRD.exe was already run in
a previous step, before running AMT_Exclusive.exe.
The following files will be extracted:
amt.exe
amt.sql
AmtCreate.exe
amtrsmove.exe
amtserver.ini
amtsweeper.exe
DBCreate.exe
dbexpint.dll
fbclient.dll
Fix Database.bat
html.txt
midas.dll
msvcp60.dll
Onyx.Install.1.0.0.3.exe
qtintf70.dll
winlicman.dll
On the Amethyst Supervisor PCs:
Run the supervisor upgrade for each supervisor:
Uninstall Interbase Client.
Install Firebird Client.
Run the supervisor upgrade.
AgentQualityReports.exe
amtsuper.exe
fbclient.dll
midas.dll
qtintf70.dll
On the Amethyst Agents PCs:
Run the USB / SLVR upgrade for each agent.
