Both AmtSup and AmtSuper directories exist, which do I use?
Postby Belinda Frick » Tue Nov 16, 2010 12:06 pm
It was suposed to copy the files to AMTSup
instead of the AMTSuper folder.
Simply copy the executable from AMTSuper
to the AMTSup directory. If you do this
you won't have to change the existing
filepaths.
