AMTMitelCRE has not recordings, but is running
Postby Belinda Frick » Fri Feb 01, 2013 2:34 pm
I am runnig AMTMitelCRE version 1.6.4.32. I see no recordings in Supervisor for current time. In Webadmin I can connect to CRE using 'Configure Cardserver/CRE', but under 'View logs' it repeats the message " Error in PacketCheckWorker 0: Access violation":
[2013-02-01 13:56:41.233] Version [1.6.4.32] Error in PacketCheckWorker 0: Access violation
[2013-02-01 13:56:45.642] Version [1.6.4.32] Error in HandleEvent_Stream_Start: Access violation
[2013-02-01 13:56:46.237] Version [1.6.4.32] Error in PacketCheckWorker 0: Access violation
[2013-02-01 13:56:49.070] Version [1.6.4.32] Error in HandleEvent_Stream_Start: Access violation
[2013-02-01 13:56:51.241] Version [1.6.4.32] Error in PacketCheckWorker 0: Access violation
Solution:
You will need to stop/start the AMTMitelCRE.
NOTE:
The issue has been addressed in verison 1.6.4.38, but to date (20130201) it has not been released yet.
