Amethyst recordings have duplicate reference numbers
Postby Belinda Frick » Tue Nov 16, 2010 12:38 pm
ZlbRenamer
Installation
Extract the executable into the directory
where the recordings are located.
Execution
When the program is started up, a window
will be displayed with a button in the
top-righthand corner labeled "Go".
To begin processing the zlbs, click on "Go".
Three directories will be created in the
same directory as the executable.
Completed
Old
Logs
The new processed zlbs will be created in
the "Completed" directory. The old, unprocessed
zlbs will be moved to the "Old" directory.
If any errors occur, they will be logged to a
log file, created in the Logs directory.
