AmtMitel has lost Comminucation
Postby Leon van Heerden » Wed Apr 10, 2013 8:49 am
The AmtMitel Application utilizes the Mitel MiTAI protocol to communicate with Mitel controllers for call information. This information is used with TNG and Amethyst Voice Recording.
When the MiTAI connection is broken the AmtMitel application generates an error messages "LOST COMMS". On an Amethyst server, this will generate a Critical error notification. It will also send another notification when the communication is reestablished.
The communication can be lost for many reasons, but the most common reasons are:
  • Network between the AmtMitel application and the Mitel is down.
  • Mitel PBX is rebooted.
Many mitel systems are configured to reboot automatically once a week or once a month. This error will be generated at that time.
2011-03-19 23:00:30 2011-03-19 23:00:30 AMTMITEL LOST COMMUNICATION WITH 172.18.1.2
The Second message regarding the hours not connected is generated if the connection is not established within a couple of minutes. There was a bug in versions prior to 1.6.4.23 that could generate this message at the same time the connection was lost.
2011-03-19 23:00:30 2011-03-19 23:00:30 AMTMITEL HAS NOT CONNECTED TO 172.18.1.2 FOR 189 HOURS.
