How do I license AMTMitelCRE?
Postby Belinda Frick » Thu May 30, 2013 10:58 am
  • Log into AMETHYST webadmin
  • Go to the License Agreement page.
  • On the top right-hand side click on the drop-down next to 'Agent Quality Management':
  • Select 'AMTMitelCRE'.
  • Click on 'Add' button.
  • Select 'Datatex CRE for Mitel' from the drop-down
  • Enter the IP address and then 'Add to System'
  • Supply Datatex Registrations with the 'Installation key' and 'ID':
  • Datatex will provide you with the keys.
  • Enter the 'License Key' and apply changes.
