- Code: Select all
[2013-08-20 10:07:12.612] Version [1.6.4.7] Error in CheckSmartWORKS: Board 1 - FW error detected
FW errror relates to Firmware issue.
Suggestion:
NOTE: While Cardserver is shut down, no recordings will take place. If you have more than one recording card the shutdown will influence recordings made by the other cards.
- Shut the Cardserver down.
- Wait at least 30 seconds to release all power.
- Power the Cardserver up.
- Do some test calls for the channel of the board that you received errors for, to see if it recovered.
