by Belinda Frick » Tue Sep 03, 2013 12:00 pm
- If you are using the version earlier than Mitel Border Gateway (MBG),
then AMTMitelCRE can record the dect phone model.
NOTE: This also applies to the DeTeWe.
For configuration of phone on MSL refer to forum post:
Configuring a Mitel IPDect base station to work with SRC
- If you are using the MBG then you need a teleworker license for each phone.
To record, you just setup the phone as recorded devices on the MSL and point it to the SRC - refer to forum post: AMETHYST 1.6.4 and AMTMitelCRE auto update MSL extensions
If you do not have a teleworker license the Mitel phone will get stuck with the message "TW license must be installed".
