How do I check number of SRC licenses?
Postby Belinda Frick » Wed Oct 16, 2013 3:46 pm
The SRC licenses is Mitel licensing.
  1. You need to log into the MSL.
  2. Select Under the 'Applications' section in the left hand margin.
      You will have 2 options depending on your version of the MSL:
      1. Click on 'Mitel Border Gateway'.
        Click on the 'Status' tab.
      2. or on older versions: Click on 'Secure Recording Connector'.
    • Click on the 'Dashboard' tab.
      Next to the 'License Information', it shows 'Tap licenses' under 'Total local'.
    Re: How do I check number of SRC licenses?
    Postby Belinda Frick » Tue Sep 20, 2016 4:34 pm
    Newer version of MBG
    This example is from:
    Mitel Standard Linux 10.3.31.0
    MiVoice Border Gateway 9.1.1.37
    Click on 'MiVoice Border Gateway'
    Click on STATUS tab
    Select 'Dashboard' from drop-down:
