How do I search for all recording on a specific day?
Postby Belinda Frick » Tue Nov 16, 2010 2:42 pm
ALSO SEE How do I search for an AMETHYST recording?
Use the above document as a guide to do a search.
Select the Date required and then All Calls to display all the
calls for the date specified.
In the left-hand bottom corner of the screen it will display
the total number of calls for your selection createria.
AMETHYST only display 10 pages/screens of information. Use the time
option to split your calls and do a second search to view all
calls.
