Listening to recording: error "SQL EOLString detected"
Postby Belinda Frick » Wed Nov 17, 2010 7:59 am
Problem
When listing to a recording gets the following error
"SQL EOLString detected".
Solution
AMETHYST 1.3 no longer supported, please
contact your dealer for upgrade options!
This sounds like a database corruption. If you ran out of disk
space, it could have corrupted your database.
You have to upgrade to AMETHYST 1.4.
ALSO SEE: How do I upgrade Amethyst 1.3 to 1.4 from the internet (Windows)?
PLEASE NOTE:
Following the instructions in the upgrade document carefully
aswell as the sequence in which it is listed.
You will need free disk space equal to the size of your AMETHYST
database.
