AMETHYST Supervisor password max length
Postby Belinda Frick » Mon Aug 04, 2014 9:26 am
AMETHYST Supervisor password max length is 15 characters.
For example if you create a Supervisor user name as :
JOHAN VAN POGGENPOEL
123456789012345678901
The default password will be:
JOHAN VAN POGGE
123456789012345
This has been noted with Supervisor versions:
1.6.5.2
1.7
