Amethyst 1.6.3+ and Unencrypted Data
Postby Leon van Heerden » Wed Feb 25, 2015 4:10 pm
Since the Amethyst Systems has moved over to Encrypted data between the services, any service that has not been upgraded to the Encrypted version will not function properly.
If you put the Amethyst server in Debug mode, you will see the message "Unencrypted data received" which means that those entries are discarded.
Upgrade all the software to use the Encrypted versions.
