SMDR for AMETHYST and TNG
Postby Lee Hendricks » Wed Mar 11, 2015 5:08 pm
Scenario:
I have AMETHYST extension side recording and TNG.
My PABX sends off call details via serial cable. How do I receive call details from the PABX for both AMETHYST and TNG?
Options:
  1. You can use a split cable from the PABX to AMETHYST and TNG.
  2. The SMDR cable must be connected to the AMETHYST server.
    SMDRLink on AMETHYST must be configured to receive call details via the SMDR cable:
    TCP Listen Port of ‘0’ can be changed to for example ‘25111’. This is the port TNG must be configured to connect to.
SMDRLink must be configured to send the call details to a TCP port. To test refer to forum post:
How do I check if the SMDRLink TCP port is sending off data?
TNG must be configured to connect to this TCP port and AMETHYST IP address, refer to post:
TNG and a network PABX
Lee Hendricks
