Supervisor 1.6 IE: recordings save as html
Postby Belinda Frick » Fri May 15, 2015 2:16 pm
When I use the 'save target as' option in IE it saves the recording as HTML.
Solution:
Right-click on the save icon and select 'save target as', change the filename to have file extension .wav.
