Critical mail: Database error in SaveVirtualToDB
Postby Belinda Frick » Mon Jul 27, 2015 12:09 pm
Entries in AMTWebadmin.log:
[b]2015-07-24 12:03:49 Database error in SaveVirtualToDB : Unable to complete network request to host "localhost".
Error writing data to the connection.
Broken pipe[/b]
The 'Unable to complete network request to host "localhost"' can be related to the database engine.
You will need to contact Datatex for remote support. This could be a database error and needs to be investigated. Or the database engine may require a stop/start.
If the event did not repeat and you can access supervisor and do searches (access the database), then the event was resolved.
