Smartworks drivers do not install
Postby Leon van Heerden » Fri Aug 14, 2015 1:21 pm
If you try and install the 32 bit drivers on a 64 PC, the drivers will complain that the installation was interrupted and could not completed.
In the Windows Event logs you will find an error code 1603.
Ensure that you are using the correct drivers.
