Integration within Citrix on Amethyst 1.5
Postby Belinda Frick » Wed Nov 17, 2010 11:14 am
When installing AMTClient with Amethyst 1.5 in a Citrix environment,
AMTClient must be installed on a central location on the network
which is mapped as a network drive.
Create a shortcut to AMTClient in the users startup.
If the client wants to integrate using AMTLink, install the COM
object in the same mapped network drive location.
Open a DOS Prompt and browse to the network location,
install the COM object with command : AMTLink.exe /regserver
The client who is integrating with Amethyst can use the COM object
and get all the details required.
Note : For the COM object to work, AMTClient should have worked
correctly at least once.
