Setup for AMETHYST 1.5 and TOPAZ with Mitel PABX
Postby Belinda Frick » Wed Nov 17, 2010 11:15 am
Set the PABX3 up to receive the data from the Mitel PABX.
ALSO SEE: PABX3 setup for the Mitel PABX unit
Once that is working, add the following settings in PABX3.
Tick "Network Enable".
Under "TOPAZ IP", add the AMETHYST Server IP
Under "TOPAZ Port", add the SMDRLink port, default 25000.
This must match the "UDP Listen Port" in AMETHYST.
AMETHYST 1.5:
Log into AMETHYST Administrator
Select "Configure SMDRLink".
Under "Plugin Name" select "PTopazPipe.so".
Set "Send data to PABX3" to "Off".
Select "On" for "Listen for UDP".
Enter the listen port under "UDP Listen Port".
This must match the "TOPAZ Port" in PABX3, default 25000.
Server Settings -> Stop SMDRLink, to stop SMDRLink.
Server Settings -> Start SMDRLink, to start SMDRLink.
