AMETHYST 1.5 and AMTTAPILINK with the Mitel PABX
Postby Belinda Frick » Wed Nov 17, 2010 11:16 am
The Mitel PABX unit:
Mitel TAPI must be installed and working.
You can use the Monitor program on the TOPAZ CD to connect to
the Mitel TAPI. Click on build list. It must display all the extensions.
The extensions needs to be configured manually on the Mitel TAPI.
Note for Mitel: In Mitel Tapi - Extension list
right click in the white section of the extension list
click on the 'Insert' button
add the new extension number
Please ask a Mitel technician to assist.
AMTTAPILINK:
AMTTAPILink will start and stop the calls. Please install on the same
PC as the Mitel TAPI.
Setup and install of AMTTAPILINK
