How do I configure the LDA409 card to record radios
Postby Belinda Frick » Wed Nov 17, 2010 12:13 pm
Install and configure the Smartworks drivers for
the analog card.
ALSO SEE: SMART analog card configuration.
Setup the channel in AmtSmartSrv.ini as "3".
3=enable vox mode
2=disable vox mode
AmtSmartSrv.ini
[NETWORK]
SERVERIP=192.168.15.1 //IP of Termserver
CLASSC=001 //Added to reference number
LOCALUDPPORT=27020 //Internal setting, do not change
SERVERPORT=27002 //Port on Term server
[CHANNELS]
2=3
3=3
[CONFIG]
WORKPATH=E:\Datatex\AmethystShared\ //Where GSM file will be written
MAXSILENCE=3000 //If in noise mode, this is how long
//the silence will be to stop recording
BEEP=1 //Disables beep in background of recording
[BOARD_NUMBERS]
2=1
