by John Richard Procter » Thu Jul 21, 2016 1:03 pm
- Code: Select all
Mirroring of the PABX to to be set to recorder destination port
Mirroring of the AUDIO gateway to be set to recorder destination port
EXTENSION to IP list which is required for the stations.ini or calls will record with EXT:EXT
Also enable permanent stations in the siprecord.ini
- Code: Select all
PERMANENTSTATIONS=1
- Code: Select all
202=10.51.241.230|1233|
by Belinda Frick » Thu Sep 08, 2016 2:35 pm
Please note: PERMANENTSTATIONS must only be used for fixed IP - no DHCP.
