by Belinda Frick » Thu Aug 04, 2016 10:27 am
NOTE: Groups was introduced: 1.7.0.55
- Log into Supervisor as the admin user.
- Select the 'Settings' tab and then 'Setup Supervisor Access' link
- To see if the supervisor login is already configured select 'Administrate Supervisors':
NOTE: Marked in RED, this supervisor will have access to all users even if groups are configured and allocated.
- First create the group - use 'Add/Rename Group'
- Allocate users to the group - use 'Users to group' by dragging from left list to block to the right of it.
- Give supervisor access to the group - use 'Groups to a Supervisor'.
