How do I add questions to the Categories already created?
Postby Belinda Frick » Mon Sep 05, 2016 12:18 pm
To add the questions to the Categories already created:
Log into AMETHYST Webadmin.
Select the template
It will list the Template name in red with all the categories listed under it.
Click on the category you want to add a questions for.
The template name will now be black.
Now you will have an option at the bottom 'ADD QUESTIONS' - click on it
Add your questions and click on ADD QUESTION button to save.
Repeat process until all questions added.
See attached screen shot for details:
NOTE:
Please use Chrome or Firefox, as Internet Explorer does not give all the options to click on needed to create the Template.
